Big Iain":t88krexw said:ian hosk":t88krexw said:Matt":t88krexw said:Remember that you can fit the new seats and subframes without removing the undertray, you can do it from inside the car.
Inside the car fantastic news, I thought I was going to have to get underneath. Are you bolts easy enough to get to then?
Matt are you using the existing Clio runners then? Leaving only This Part in the car? Which you then bolted a subframe too? Which subframe? and does the handle interfere with the seat?
Hi,
I took my whole OEM seats out complete with runners that bolt on the floor. You can get to the bolts from inside the car through to unscrew them then bolt the new subframes and runners in place.
