I now have a new fuel tank and pump mounted up front. (The setup may look familiar to a few of you!)
I ran coated steel hard lines under the car to the rear. The supply and return lines are connected to a Malpassi regulator. The output of the regulator is temporarily feeding the dual Webers on the (soon to be replaced) Alpine motor. The regulator is set for 4psi and the motor runs fine with the new feed. The only problem I encounterd is that the fuel gage sender in the new tank in not compatible with my gauge. The cheapest fix was a new gauge.
Next task is to fabricate a mounting bracket for the ignition coil unit.
