Orbisound ?
mossyv6":3sg5d40s said:
Liquid":3sg5d40s said:
I had orbisoud on with cats in place and sounded good. Mossy has that set up (currently......) ;)
Sounds like a video for the summer pal :approve:
Good call... how about a multiple 'zorst off'. All makes and set ups.. should be a laugh! :)
Yep, car will not pass MOT so each year unless you know a friendly (dodgy) MOT man you would have to swap them out, not the easiest job!
I thought about it and couldn't be bothered with the hassle for the very few miles my car does
Hi Colin,
Same here.............just a back box would do me............couldn't do with all the messing about every year - would just be a pain in the a**e.
Liquid":175kerc2 said:
Downpipes go to each bank Of orbisoud Ali. Same as trophy set up.
Trophy setup is completly different Matt. Both banks merge into 1 pipe. That way it equalises the exhaust pressures to each bank. There should really be a merger somewhere.
So the only way to keep the light off is to have just the Backbox? What about the full system from orbisoud?
Think the Janspeed system with sportscats doesnt put the light on. Not sure if that is the one Shaun has..
The light will only go on if the primary cats (first pair)have been removed upstream of the lambda sensors. There's no problem having full systems with cats in different places if you wish. Just so long as the lambda sensors can read the gasses after the cats.
Almost anything sounds better than the OEM backbox so yes would be the answer. Whether Orbisoud is better than the other miriad of options is very much a personal preference thing.
If it was me I would skip first base and head straight for collector delete at base two. Collector snaffles the sound, it's weighty and generally full of AIDS.
Why not consider the spike janspeed?
A few on here have it now including me. And we all rave about it! Absolutely perfect sound!
:approve: Seems to solve his issues with lights on.
Hi Gents,
I was only asking about the system.............that's all.
Heard good things about it but knew nothing about it if you know what I mean :s
Just trying to learn as much as I can as I go along.
My car came with a sports exhaust but just too loud for me at my age - 15 years ago I would be loving it.
Just trying to find the perfect exhaust "for me", if there is such a thing...............I really need to have a good listen to some more YouTube stuff etc etc
Many thanks.
