Speaking of RS monitor, do you have any idea's what wiring swaps are needed so I can ditch the crappy carminat tomtom in my Meg 3, and fit an RS montior ?Android auto was easy to activate with Renolink (I was careful this time) had to make an adaptor harness for the obd socket first to allow comms with the headunit. Looks like you can change lots in there including boot up screens. I won't play too much though. RS Monitor next
no idea tbh. On the clio i need to actually write some extra info to the eeprom on the head unit. @Brigsy might know how to do it on a meg 3Speaking of RS monitor, do you have any idea's what wiring swaps are needed so I can ditch the crappy carminat tomtom in my Meg 3, and fit an RS montior ?
i got my lead from one place, the software from another. Then you have to go through a bit of back and forth to get the 2 paired up and working.Got a link for the Renolink kit?
I don't think so, Android auto should still be active in the background but the RS monitor opens up on top of everything else if that makes sense.Can you get Apple CarPlay/Android Auto on that screen??
WOW, that's some clever stuff!!So, the car/dash doesnt auto adjust the power graphs so i did some digging.. I found some info on a Spanish forum about rewriting some of the scales and info on the headunit. Gave it a go, taking data from my dyno print out, converting it to nm, then halfing it and then changing the results into hex. I then typed them in on the file from the eprom and reloaded them to the head unit. Needs to be refined a little but proves it works. I may try and adjust alot of the temp sensor settings if I can find them so I can see the info from a cold start vs when the engine is over a certain temp. Intake temps current lowest is 20 degrees, water is 70... not that I'd be driving hard till it was ready but it would be nice to see it if possible.
View attachment 215586View attachment 215587
Renault injectors?166001518R
Meg 4 rs injector part number. Dropped it here for ref if I need to find it in the futureRenault injectors?
