254 (Renaults are great at disappointing)
Higher flow at the same pressure. The in tank pump is fixed at 5bar and feeds a high pressure fuel pump and direct injection injectors. The info I was given from @tutuur is that the stock in tank pump will be flat out at around 285bhp, hence the higher flow pump. The hpfp and injectors will be maxed up near 320ish bhp.272..... was the fuel pump change to give same pressure at higher flow rate or higher on both. Is it on std injectors? What is their limit? Is it dependant on the fuel pump? I guess it must be. So many questions, so little time...
Looking at my old map file from the 21 you're not too far off.If you got all the sums correct the maximum amount of advance you need to add is about 28 degrees from tdc at max Revs and full throttle
On an EFI car the gadgetry does it itself, unless you tell it not to. I think the first generation of this Renault wise was the 21 Turbo era, I have press releases where they call it out as a 'feature' that the engine management could cater for different altitudes and temperatures very effectively. Todays modern kit will have a number of tools at its disposal to adjust, around fuelling, ign timing, valve timing (and lift in some cases but I dont believe Renault have done that yet).What I am wondering is if the mixture is weak at a certain point in the rev range, how do you go about richening it
Mk4 RS's have the M5M engine and the direct injection pressure runs over 2000psi I believe (correct me if im wrong anyone), so i suspect it doesnt give a shit about an increase in manifold pressure, I think though if the tank pump can't supply enough to the DI system with the raised delivery requirement once mapped it could get quite nasty. Otherwise it has all the parameters above at its disposal to essentially run closed loop fuel and ignition to a point. They have a crazy amount of sensors to keep everything in check. I changed an engine in a 2016 Kadjar recently and it had THREE knock sensors and that was only a little 4-pot 1.2 turbo.I'm also thinking that the injector is probably not just a single squirt, but may be in several phases, so thats how the changes are made??
