5 GT Turbo NA Renault 5 Project From Azores
if you want to keep the NA engine, pipercams will regrind your cam to a NA spec r5 one if you wish. remember a piper NA 285 is actually 288 deg duration ;)
Thanks smart5. Checking the repair manual, I've found that 847 engine is the same as C1J. So, dBilas sells camshaft for this engine which I think it might fit mine.
I've been doing some research, though.
http://www.dbilas-shop.com/Products...3-1-4-847-812-Performance-camshaft::5428.html
I was thinking of this one, in conjunction with Bike Carbs. Some more mods to get a realiable engine, such as some uprated valves, springs and retainers. What do you think?
