if you want to keep the NA engine, pipercams will regrind your cam to a NA spec r5 one if you wish. remember a piper NA 285 is actually 288 deg duration
Thanks smart5. Checking the repair manual, I've found that 847 engine is the same as C1J. So, dBilas sells camshaft for this engine which I think it might fit mine.
I've been doing some research, though.
I was thinking of this one, in conjunction with Bike Carbs. Some more mods to get a realiable engine, such as some uprated valves, springs and retainers. What do you think?
