my engine conversion to valver
G
Guest
what can i actually use from my rt engine bay for my valver engine?
trying to save money :D
Gearbox is prob the only thing, I think everything else should be changed for safety more than anything!
Craig
i knew about gearbox. can i use rad, some hoses, header tank, ignition coil etc. can i leave all power steering stuff and brake stuff in engine bay when i do it
think power steering and brakes master cylinder are ok.
rad hoses header tank are different i think.
As maxiboy said, power steering and brake stuff will be fine... are you running 16v brakes already?
Other bits Im sure you would need 16v items, radiators are different in terms of cooling efficiency etc.
Craig
not 16v breaks but uprated suspension already. gonna do uprated brakes after conversion
