Fordy
Heres a quick write up of todays task,
All parts came from Altec Automotive as i found them the best priced and use fast dpd delivery for free.
35mm2 cable ALT/PVC35
8mm stud straight terminals for 35mm2 cable pack of 4 - ALT/BSE35-8
90 degree starter terminal pack of 1 - ALT/BSE90B-35-8 - i ordered a few incase of crimp issues.
Mega/midi fuse box - ALT/FH260158
200amp genuine mega fuse - ALT/MF200
Positive battery terminal - ALT/BT4POS-02
I already had a single midi fuse holder with a 50amp feeding a fusebox for my megasquirt, aem uego and coil pack etc - ALT/FUSEMIDI50
I recommend you fuse the interior feed, its not fused from factory. Currently still trying to figure out what fuse to fit. for now i have removed a lower stud in the fuse box and wire gone straight to the top busbar.
It starts a lot better as expected and mostly i have proper voltage into the car and no volt drop now so hopefully the interior/ speedo etc are less temperamental
I really need to paint the engine bay but its function over form and a very last thing on my list of jobs
Next up is to freshen up the steelies, enjoy any of summer if lockdown lifts and plan the jenvey fuel injection setup
