C
Coops
I run an F7P turbo, so its map sensor based mapping to the standard chipped ECU
currently running 15psi (1.1Bar) through a renault 21 turbo 2.0bar map sensor (to the best of my knowledge thats what it is)
to up the boost i guess i require a new 3.0bar sensor as the first 1.0 bar is atmospheric right?
any advice and info on what i need and where from much appreciated, what do you guys use if you up the boost over 1.1bar?
cheers
Ben
cheers
Ben
