elviscat
Hi all,
hope all is well
i'm having an issue with idle to explain, if i pull up to a junction, or take it out of gear before i'm at a stop, idle falls to almost stall, (rarely stalls, but it does happen) so i have to keep it up a little by keep giving it a little gas, once the car has stopped the idle slowly recovers from say 100rpm to 900rpm. sometimes it seems if i let it recover to 900rpm long enough to solves the problem, until the car is turned off, once started again the problem reoccurs once again only to be fixed if i am stopped long enough time to let the idle recover to 900rpm and a bit longer!
sometimes it also seems if i leave it to warm for 10 mins the idle problem also isn't as bad, but comes and goes along the drive. Also if the car has had a long drive and is warm the problem doesn't exist at all.
Is this idle sensor, crank sensor?
any help would be appreaciated
Ta in advance
hope all is well
Ta in advance
