I can confirm that the one door in question does indeed have the torx pins in its hinges. I swapped the original (looked like steel?) bushings for the brass type, and fitted the correct torx pins. The threads were fine thankfully. The three other doors do use the splined pins. The fourth door must have been replaced in its past.
The oil cooler also fitted without too much hassle. The original one just unbolts from underneath after removing the oil filter. 27mm socket I think it was. The Renault/Nissan/Vauxhall/Volvo/Mitsubishi diesel one I bought is thinner by about 6mm, so I had to machine down the central hollow bolt by the same amount to allow it to clamp up. Coolant pipes in a slightly different position, but hoses went on fine without messing.
Other jobs this weekend were put the interior bits that I removed back in and carpet down where I had it up for the welding.
MOT is booked for Friday - wish me luck. The MOT guy said it'll bring back bad memories when he sees the 21.
Still a couple little niggles. The wiper stalk needs to be pulled a certain way to get the washers to spray... I might try to take it apart one evening to clean up the internal contacts before the MOT. Oh, and one of the valve cores in the wheels seems to be duff. One of the tyres keeps going down, so need to put in a new core when I find my removal key.
What do people do about the fuel gauge? Does a standard analogue one work from a lower spec 21? My LCD is not the best, so reading the level is hard. Is there an independent low fuel lamp?
