stephenvenning
UPDATE:
Today I took a last minute day off to get bits finished off on the clio, getting very close now to starting her up. First on the list today was to assemble the shocks with some H and R springs, the shocks were painted gloss black and the rubber boots and top mounts were given a through clean, the springs were then installed using some springs compressors. Id imagine these will be swapped out next year for some BC coilovers but funds dont allow that at this moment in time
I have also started to finish off my fuel system today, Ive plumbed in the feed line and figured out how Im going to mount my fuel pressure reg. A new bracket will need to be made for the pressure reg. The return line will also be plumbed in when Ive got the car up at running before mapping. i wont need to the HP fuel pump on stock map and on running the engine in so no reason it to complicate it at this point, it will be one less thing to bed in and setup considering I have a new clutch, flywheel, engine internals, rebuilt gearbox and other bits.
Drive shafts were also given the OCD treatment and wire brushed followed by a coat of smooth black hammerite.
Tomorrow I should get the driver side suspension sorted like hubs, struts, driveshafts etc. Im then going to sort out positioning the coolant resouvior as I have a feeling another bracket will have to be made up. Ill update again sunday.
Thanks
Thanks
