I actually still have a BNIB Sabelt RenaultSport steering wheel with a carbon cruise bracket already wired and ready to plug n play, along with an aftermarket boss. So basically everything to swap over and retain the cruise and horn functions.
How much are you after for it them buddy?
The sparco wheel looks great. How much did it set you back ?? ive seen them at £240, fancy one for the van
They are £180 from r sport I think mate
So today I fitted my wishbones which were the final piece of the puzzle, this means that every bush, link, joint and bearing has now been replaced.
The powerflex black series are very stiff and were a nightmare to manoeuvre into place on my own.
A picture from the pfc expo too
Is anyone able to confirm that 8200627595 is the correct part number for an r26 rear xenon level sensor loom?
So some of the clips had snapped on one of my grills so I ordered a new set from Renault, a new outer cv boot because of of mine has a little nip that I think will eventually tear and some push clips for the wheel arch liners.
So the loom for the rear xenon level sensor arrived, hopefully this is the correct one, along with some genuine front mud guards to try reduce the beating the rear arches take.
I haven't really done much to the car lately, however today I fitted the rear xenon loom which is one of those horrible Renault jobs, navigating the loom around the fuel tank and over various heat shields to the sensor.
I haven't really posted anything on here for a while as nothing much has been going on. As of late I've had a new windscreen in the Megane, an offside driveshaft and some new led numberplate lights from xenons online.
Going to give it a oil and filter change this weekend.
I've almost had a year now and including the car spent nearly 18k [emoji15]
Finally fitted my powder coated under brace
Painted the front grill today in some plastic paint to bring it back to life, looks a lot better now.
Also fitted an r26r washer bottle.
And Snappy delivering the goods [emoji51]
New battery today and new drivers window module.
Last night I had the joy of replacing the drivers side driveshaft seal as it had started weeping. This is a horrible job laid on your back on the driveway.
The seal had actually tore in half [emoji15]
Damaged seal
Anyway fresh Renault seals and box oil, I will get round to changing the passenger side one when I have some spare time again or access to a ramp, but as it wasn't leaking I will wait a while.
Debating a wheel change and seats next!
Money well spent imo. Good to see someone looking after a mk2.
I am getting tempted to get some proper fixed back buckets for mine, the recaros are comfy but on the track the support isn't brilliant. Need to wait a while to get some money mind you
