Switched out the under headlight trims from the headlights supplied with the car (which didn’t have the manual adjustment function) to a new pair I managed to come by.
Always like to use new headlights on my car rebuilds, as it really brightens up the front of the car:
You can see how the new (outer) ones look LOADS brighter
Next I did a little DIY refurbishment of the starter motor heatshield:
With a roll of adhesive backed aluminium:
It doesn’t make it brand new again, but has certainly given it a bit more rigidity and now stopped if fraying any more.
I then whipped the oil sump off:
Thankfully I found no big lumps of metal in the bottom of the sump, so things still looking healthy… (famous last words)
Then I removed the timing covers:
To show an OE Renault Timing Belt fitted that was still in good condition
It was exactly at this point I was reminded why I always take the engines out when I’m doing work like this:
Just look at the state of that lot!!!
It’s near impossible to fix this properly when the engine’s in the car… I want to try & make this engine oil-tight
Thanks for stopping by
