Clio Big Steve’s Clio Williams 2 (World Cup Williams) 🌍
Breakdown continues, so I can get the engine out for a full going over.
O/S Wheel and driveshaft out tonight:
And it appears there IS a bigger brake kit fitted to this car as advertised!! Never seen one like this before with little anodised aluminium brackets..!!
It appears the standard Clio Williams calipers are present. I know people swap to the 172 wide track, for the Clio 172 Calipers… but how different is the 1*2 caliper carriers vs the Williams..?
Anyone know??
Wish I’d seen this earlier. If you’ve got ph1 172 hubs you can use the valver hub flange (I guess Willys are the same) and press them into the 172 bearing
