Clio Adeys Clio 182 with added F4R+t content
wont suit the outlet on the 225 turbo, its directly above the exhaust manifold. oem part is prob designed around that situation nicely.
nice that looks the ticket. will only need to sort the bottom part of it to the block/sump if i get hold of that. cheers. i did a quick Google but what i wanted didnt come up
scrap yard raid for a dash vent and ash tray for the clio along with another firm favourite from the house of endor, a small laguna splitter. loads cheaper and alot more robust than a clio cup item or carbon equivalent.
i really like them, different from the normal oem wheels, turinis, oz f1s, 2118s its good to go against the grain
I like the wheels adey, are they currently on 195/45's? the new tyres to go on 50's, will look better if they are. I'd get them powder coated a gloss black or something, would look great!
cheers (y) yeah still on the 45s. fat 50s ready to go on that will fill the arches a bit better
they do up front yeah, its on the cards (y), on the rear you can space the stub axle and change the alignment at the same time which ill prob also do
Good digging. Thats the part numbers for the oil drain feed for a 225/r26 TDO4H-14T?
looks to be based on the parts lookup page? seems to be a shared part from all the 2.0ltr T engines on cross referencing parts so i might be able to get them cheap from a breaker (y)
ill defo get the first section (item 7) and probably the lower pipe (item 6) plan will be to chop the lower and use it to join into the sump
