5 GT Turbo 7 pin headlight relay
jake
Evening all
My GT turbo has a faulty headlight relay, which I need to replace.
However it is a 7 pin item rather than the normal 4/5.
Does anybody know whet the extra 2 connections are? The haynes manual didn't seem to contain it.
I didn't have a spare one to hand, but it looks like a 5 pin one will fit, I assume that it either won't work or I will lose some functionality?
Cheers
Jake
It might been pink once upon a time! the plastic cap was missing and it had tape round it.
Dip dim would make sense though.
Do you know if a normal relay will activate the dip beam normally?
I wouldnt risk it. Go find any R5 in a scrap yard, that will be a generic part to all fives, and probably other models around the same period too.
