BENZO 19 16V
hey mate any more update on the email i sent for car parts,,
Jay, you are better off getting those off a late year 3 door mk1 clio, cut then front end down to fit the 19.
how much 4 the head rest mate
I have a 1991 Phase 1 3 door. Would the leather interior fit?
What's the drivers seat condition / wear like?
Thanks
will it work for the backs? mines are in poor condition. i know ive gotta faf around and cut them to suit to fit.
Dunno, wouldn't have thought so, since on the rears both ends are finished/capped so if you start cutting bits to adjust the length then it would look awful. It may be possible to remove the little plastic end finishing cap from the strip, cut the strip to length, then refit the cap. Might not look 100% but probably better than what you've got now.
On the fronts the cut end is concealed beneath the wing mirror baseplate so it's not an issue.
I am looking for the following:
1. Aux water pump relay and captive nut that holds it to the body. (This is the small black electrical module mounted to the inside of the near side wing. It is basically square, but round where the connector fits on)
2. Plastic grill over driver's side floor air duct
3. Accelerator cable clip (The plastic clip in front of the engine that holds the accelorater cable out of the way)
4. Internal cover of rear lights - the removable plastic cover inside the boot
5. Heater control panel with bullb(s)
6. Rear fog light switch
7. Hazard light switch
If you still have these, can you propose a price?
Thanks, Carl (Putput)
hi james
can you let me know if u have the parts i am after please:
standard airbox and ducting/pipes
nearside central locking mechanism/motor
OSR side rubbing/bump protection strip
the two lugs to fit the spark plug cover on
