1994 16v hatch breaking - £Various
James,
All seems quiet. I am still looking for these bits, plus a few more (added below). Are they still available?
1. Aux water pump relay and captive nut that holds it to the body. (This is the small black electrical module mounted to the inside of the near side wing. It is basically square, but round where the connector fits on)
2. Plastic grill over driver's side floor air duct (near gear stick)
3. Accelerator cable clip (The plastic clip in front of the engine that holds the accelorater cable out of the way)
4. Internal cover of rear lights (driver's side)- the removable plastic cover inside the boot
5. Heater control panel
6. Rear fog light switch
7. Hazard light switch
Also need to add these parts……
8. Aux. fuse box cover. (The clip on plastic cover on the engine side)
9. HT lead set
10. Courtesy light door switch
11. Fuel pump relay
12. The plastic screw type clips that keeps the main fuse box cover closed
13. The plastic screw type clips that hold the F16ie plate on top of the engine (only wanted if heads are in perfect condition).
Many thanks, Carl (Putput).
Location
Country: UK
County: BRISTOL
Price
£Various
Description
Breaking for spares. I've already pinched the rear beam out of it and also want the wheels. Gonna make a decision about the engine and box this week as may keep that for when I blow the chammy up!
Leather interior, dash, switches, panel, lights etc etc all available so make me an offer if u are looking for any hard to get bits
hello mate. how much for the steering wheel, and i need one alloy. meny thanks. if u can text me bk that would be good. 07943533994 oww and do i have to collect?
