DaveL485
Staff member
HT leads cleaned and attached
New fuel lines fitted from the hard pipes to the reg/rail
And there's that little woggle for the TDC sensor wire
Cleaned, painted and fitted the power steering pump rear support, this is also an earth point and the bottom bolt holds the oil level sensor bracket too, which was also all fitted.
Inlet manifold support cleaned, painted and fitted
After so long sat doing nothing it seemed surprised to be back in use!
