Alpine 1968 Renault R8
  • Thread starter Thread starter Adey
  • Start date Start date
  • Featured
Pretty decent afternoon down at my mates rollers. Rolled in with a 64 bhp pull and got better from there. Did a few runs to check fuelling and then spent an hour doing pulls whilst adjusting the dizzy. We were actually backing the timing off when we started seeing the number climb. WE didnt have a proper timing mark to go from so made one with some paint and adjusted from that point. Ideally I need to get a proper TDC 0deg mark on the pulley and cam cover. Took 18 degrees out of it and gained 10bhp! Car behaved really well whilst there until the end where it gained a hole in the power low down and top end started dropping. We locked it a the last good timing value that got good power and left it at that.
On the way home the hole/flat spot got bigger and then after a detour to the shops the car promptly stopped and wouldn't spark. Coil was too hot to touch so I think its dead, pretty sure it was a Chinese knock off that I had kicking around. Need to get a genuine Bosch or Lucas one in there I think. Will be interesting to see if it runs sweet again with a new one on.
Anyway, ditched the car, went home and got some tools, 30 min later when I returned it ran but only just, but good enough to get me quarter of a mile through the town and onto my drive ready for some investigation tomorrow.
Ill have a video together for you in the next few days (y)
20241129_184840.webp20241129_170302.webp20241129_163853.webp20241129_135558.webp20241129_134405.webp20241129_133223.webp20241129_132849(0).webp
So about 75 Bhp. That's a great result. A hot coil can be an indicator of too much coil on time. If you possess a dwell meter check the points dwell percentage. It is the most accurate way to set them. too small a gap causes too much on time which in turn heats the coil.
Dwell percentage should be around 63 plus/ minus 3. This is changed by adjusting the points gap. Start with the points about 15 thou from memory. Later external adjust points were great clip on the dwell meter and turn the nut on the body to set.
Of course pissing about with this also alters your final timing value, so it should have been set before starting. Good news is it won't change it much.
Happy Days
In fact. I think the problem started on the rollers, a hot coil starts to break down gradually, then the missing starts, then it gets worse. Long periods at low rpm worse as they increase coil on time. Been there, done that.
Ill double check the dwell, I think I have a meter in the garage actually. Sure I set it a while back when I first got the car running, unless they move massively? its ran on 2 engines prior to this. I'm leaning more on the coil just being chod, it about a 3rd of the weigh of the 2 spares in the garage. I have a spare old ducellier but have ordered a new valeo item I can collect tomorrow from the factors. I think it started dying on the rollers too tbh. Still decent as long as I can get it running again :D and ill keep a spare in the car for longer journeys just in case.
Hi Adey,
If you recall, and as Steve previously advised, the early 330 R8 Box which you have factory fitted, has the weakest internals mainly the sunwheel tooth design & form, these Mk1 teeth can shear off easily when doing more sporty starts [worse with the addition torque of the 1400] also you will have hollow hardy spicer cross pieces within the universal joints housing the rubber stop at the halfshaft end.
These joints can be upgraded by disassembly and fitting solid hardy spicers which easily resolve the shattering problems, incidentally 8 out of 10 of my transaxle blow ups with std 330 boxes had shattered U/Js in the axle tube which then took out some teeth off the puny pinion gear, and or sheared sun wheels, breaking just where the shoulder is.
The R8Gordini solution was to keep the sunwheel tooth design, but they cleverly doubled the number of planet gears, but this itself revealed another issue with the cross pin and 2 shorter pins which would loose their rollpins and trepanne the box casing. Oddly enough the sun wheels were I think of a better quality material as they appear a bit shiny but they still snapped in half. Pat Bridger in the ex Goodwood, race car broke one in front of me as he left the start line at the Prescott La vie en Blue Hillclimb.
When I was pioneering the build of the first big Wheeler box in the 1980s using the R16 TL/TS 336 internals suitably modified this cured everything that had previously failed and I also had fitted solid U/J centres. locked in with grubscrews and Loctite bearing fit, these days internal circlip groove machining is the norm, making servicing the joints a lot easier. The joint kits were then BMW or Alfa or whatever.
The 336 diff ratio is 9x34 [ 3.777 ] not bad if you use 13" diameter wheels with low profile tyres.
A cheap and quick stop gap upgrade would be to find an R10 1289cc 4.125 later box [ like what your current bellhousing came from], this has strengthened planet gear teeth and a slightly taller 2nd gear ratio and bigger diameter crown wheel bolts, and bigger detent balls but thats all, fitting a pair of updated U/Js would give some insurance against the usual failures.
In period the R8G had the option of Factory homolgated upgraded pair of Group 2 U/Js solid centred with the halfshaft ends bored to receive the rubber bump stop My present South African 1135 Gordini came with drilled half shafts but no upgraded U/Js
When I later built the first 5 speed Wheeler big box, I used the internals sourced from the 385 R16TX box, and or 385 R5Gordini Atmo. these were fitted into the above but retained the R8G 353 5th housing and 5th synchro, and its factory gear selection, the diff ratio had now become shorter i.e.3.9, but R8G boxes are extremely rare and have always been expensive.
I would recommend that if you go down the big box solution then consider the 336/330 4 speed hybrid, a Quaife ATB is also available for this 10 bolt crownwheel found in the R16/R5G and is what I use in my current R8G Competition Car, but this very expensive diff is not necessary for road driving, the std R16 big 10 bolt open diff is beefed up everywhere and does not shed teeth or shear sunwheels.
I have built numerous boxes for my various competition use and for other Renault enthusiasts and I do not know of any failure to date.
These days exotic rear engined R8 / A110 boxes based around 353 5 speed boxes are available on line, with straight cut close ratio dog engagement gears and plate type LSD
but I read that they have their own problems, a friend hillclimbing in Spain with a Dauphine fitted with a 1550 Sacco unit has much to his understandable flustration, had 2 of these specialist these boxes fail on events.
The 330 Series Family of Factory Boxes appeared in later production and slightly altered in many FWD Renaults over the production decades, and as the particular model engine capacities are increased, they are suitably reinforced, mainly all in the final drive dept, i.e bigger diameter crown wheel and pinions with bigger bolts and bigger sun wheel splines, oddly the general bearing sizes seem to remain virtually the same , as do the synchro designs, but with some mods to the synchro baulk ring ramp angles.
I did once have a borrowed Hewland Mk8 5 speed cr/sc dog box from an R8 for evaluation a while back, this being based upon the VW beetle box , this particular box was converted to take R8 Swing Axles and the top mount, the idea was to learn about it and maybe utilise the gear clusters for our R8 boxes, The technical issues were just too much to resolve without a lot of machining saying that refurbished matched gear sets in pairs are cheap on ebay for the Hewland and ratio choices are good as well.
My 1951 4CV which was a loose build tribute copy of a works car, had an extremely rare Redele /Pons "Claude" 5 speed competition box with a helical geartrain but with dog engagement [a crash box] all 5 gears were fitted within the 4CV 3 speed die cast case with a 22mm spacer as well, as the original wide synchro hubs had been deleted, the final drive was a mountain ratio 4.9 .
When I first drove it to test the car I could change up OK through the gears but changing down and double declutching as well meant missed gears, not ideal in my book, so I made a mental note not to pursue the Hewland version any further. I suppose in period it was a hot transaxle to have in a 750cc 4CV.
The current Racing fraternity running the Formula Junior Cars race series which mainly run Dauphine Gordini gearboxes which is a named transmission in the Formula Rules Book, and which is similar to the above Claude box, were ringing me as they wanted to borrow my box to back engineer copies for their race cars-- Funny old World ! .
Cheers
Dave.
great info. I think at least finding spare should be on my next list of things to get then... and take it easy with the awesome launches it can now do.
I was offered some "parts" boxes a while ago that were, so say, the ones I needed to build a 5 speed. Though bar getting parts, making one would be well outside of my ability.
they were a later 330 box and a 385 box, does that sound like what I need?
Yes they are, the 385 is better to be an earlier example Pre 1980. If you can get pictures I can try to identify, it's not easy as Renault changed the spec without changing the Nomenclature. Typical........
Hi Adey,
Steve has now answered your question regarding obtaining the R8 donor upgrade boxes and as he has now surpassed my decades of knowledge gained when building my original big Wheeler boxes for myself and customers, he is now the font of all knowledge when it comes to what are the best parts to procure, bearing in mind that all boxes are getting rare and difficult to find.
Cheers
Dave
Already onto the next bits, I'm trying to hunt down an old EFI Parts 36-1 trigger wheel setup to bolt onto the crank pulley. This will give me a trigger to add mappable ignition, I may use something like nodiz or omex on there.
I've also managed to find an old, dished, moto lita steering wheel. Period parts and the company is still active in the UK, so a boss kit for the R8 was ordered at the same time. Merry Christmas car :D. Should make it a little less like a boat to steer, and adds to the old gentleman/Cafe racer look. Should hopefully be here by next weekend (y)
Hi Adey,
Interesting progress so far with the R8, so as you are now getting the steering feel improved with your new steering wheel, It might now be the time to consider fitting a quicker ratio steering rack.
For road use an R8Gordini rack which will be a gentle upgrade, this has a extra tooth on the pinion, i.e. 7 in lieu of std 6 this helps with catching the back end when it steps out.
We ex competitors use the 9 tooth pinion which enables the driver to make pretty quick steering inputs without flailing elbows etc.
The only down side is that the internal return spring has to be deleted as the rack bar now has eccentric bushes to accommodate the larger diameter pinion to mesh correctly. Parking the car at the kerbside can be painful if a wheel just catches the Kerb, and can hurt your thumb as it snatches out of your hand.
Duncan Topliss in Grantham has pioneered a kit of parts or a complete 1 stop services exchange of these quick racks, his telephone number is 07882 374303 if you are interested..
Cheers
Dave
Hi Adey, I'm from New Zealand and don't post a lot here but I saw your request for a trigger wheel. I've had considerable experience about this issue, Steve Swan is aware of it, so I can only tell you what I have done. You should shy away from my methods because it didn't work.
I had trigger wheel laser cut, cheap as chips, and welded them onto the original crank pulley. I use a MegaJolt system. Somehow the added weight or diameter causes a vibration and causes metal fatigue. I have lost 4 of these trigger wheels in 15 years of racing.
Steve Swan put me on a Ford 1600 wheel that is made from a solid billet steel. I have ordered one and I am now busy fitting another trigger wheel to it and it won't be welded, but screwed.
I will attach photos of my setup to give you an idea. First the old way that you shouldn't do and then the new way as I progress with the fitting.
This was my first attempt. The pressed metal pulley came loose from the collar. You could see it and not even the V-belt lost its tension. Note the markings of the fallen key that I've put on it. The first photo is in line, the second photo is about 30 degrees out. That meant the timing went out by 30 degrees and I destroyed a piston.Pulley1.webp
This next photo is from the front.
Then after another 2 failures I used a later type pulley. The ones that is a 2-piece unit as used on the R9s and R11s. I machined the front bit off and welded another trigger wheel on.
It didn't last long, 3 events or 8 races.
So, if you are interested I'll post the new solid pulley method on as I go along.
Regards, Renoholic.
@Renoholic . I think there must be some harmonic effect that causes the cracking. The reason Burton did the solid steel pulleys for the crossflow, is that their originals are prone to cracking and are also pressed. The pressing must create stresses in the metal which is then harmonically destroyed by the crankshaft. Especially at high RPM. Now who here uses high RPM except you, me and @Wheelers Workshop.
@Adey. Renoholic AKA Frans has been racing R8's for a long time and his results prove just how well they punch above their weight, when properly sorted.
