Lankan":1vhf286a said:Jon, just noticed that your Vee has become a bit of a hit on YouTube: LINK
Good to see it getting some stick! :approve: It's no doubt done more miles on the dyno now than it has on the road!!
You can hear from the video that it's not being taken past 4k rpm, as there is a misfire causing overfuelling, massive flames, and a general levelling off in power. Mechanically everything is A-ok so it's most likely an ignition or wiring problem. Scott is looking into it and seeing as it's back there it'd be rude not to add a few more bits and bobs.
Small hiccup, but then that's what "being the first" usually entails!
