Steve-V6-D61
Today I went to get the car lazer aligned or in this case infa red aligned.
The compay I used is based in Tonbridge, they have the same kit as Demon Tweeks by the look of the print outs. They are MTMC on 01732 369880
The Cost was £70 for all four corners to be checked adjusted and rechecked with a before and after print out.
They did a good job and there only a mile from home, did have one problem, an OIL leak, they kindly dropped the engine under shield, after a bit of a poke about we found it was the O ring on the gear box level plug.
So after trying to reseal it without much luck, I’ve ordered a new plug and washer, I may of over tightened it, but I would recommend getting a new O ring if changing the gearbox oil.
So now we are tax'ed, MOT’ed and all the wheels are pointing in the same direction.
Progress at last.
Steve
Progress at last.
Steve
