Wheel alinment
Steve-V6-D61
Today I went to get the car lazer aligned or in this case infa red aligned.
The compay I used is based in Tonbridge, they have the same kit as Demon Tweeks by the look of the print outs. They are MTMC on 01732 369880
The Cost was £70 for all four corners to be checked adjusted and rechecked with a before and after print out.
They did a good job and there only a mile from home, did have one problem, an OIL leak, they kindly dropped the engine under shield, after a bit of a poke about we found it was the O ring on the gear box level plug.
So after trying to reseal it without much luck, I’ve ordered a new plug and washer, I may of over tightened it, but I would recommend getting a new O ring if changing the gearbox oil.
So now we are tax'ed, MOT’ed and all the wheels are pointing in the same direction.
Progress at last.
Steve
Steve
Could you paste the copy of the print out on here so I can check to see if its like mine. I am very sceptical to whether mine is aligned right.
Thanks
Kev
I'd recommend anyone to get this done, I had mine done at Demon Tweeks (quite a while back) and the Vee is definately more stable at higher speeds as a result [smilie=yay.gif]
Phill
