james":1ossj8ei said:item 1
INJECTION RAIL
96 30 333 080
£22.07 GBP
INJECTOR SEAL
77 01 476 833
£27.83 GBP each
James, would you be able to know whether both parts are in stock or are on back order with France?
INJECTION RAIL
96 30 333 080
£22.07 GBP
INJECTOR SEAL
77 01 476 833
£27.83 GBP each
SPIKE":te9ql72p said:Shinji,
I really don't think its the fuel pressure, but get it checked. you should be seeing around 55psi static and 52 running, anything close is ok.
To check and adjust the timing is an arse of a job but not as bad as changing the belt. tell them to pin the crank first and time all the pulleys to that position, no need to remove the belt again just the top cover and the bottom pulley. I assume you have explained the fact that the car was fine before they fitted the belt?
See Spikes comment.shinji":16apwoqh said:SPIKE":16apwoqh said:Shinji,
Again thanks SPIKE!! :salut:
Yep, explained to them that the car was all fine before the belt change.
Can I assume that checking and adjusting the timing do not require the engine to be out?
Training competence, what you mean? i'm not fick you no!rustedandrotten":1uprdjm7 said:See Spikes comment.shinji":1uprdjm7 said:SPIKE":1uprdjm7 said:Shinji,
Can be done with engine in, just need to take off the covers to access the positions to re-locate the timing pins to prove timing is correct, ask to see all pins in place, should be 5 not 4 as per Renault service kit!! Simple to do and give piece of mind. I refer to my earlier comments, that this until they can prove otherwise is their problem so tell them to sort it, otherwise ask for independant assessment or repair by another competent person (which in your case would be very interesting!). BTW have you asked to see training competence for the guy(s) working on your car?
This is a main dealer and should at least have this. Having lived and worked just outside HK for several years on the mainland I would be checking!! Butchers bakers and candlestick makers with a propensity to fiddle and flick every switch and knob they get near to!! :rofl:SPIKE":2ybjl64z said:Training competence, what you mean? i'm not fick you no!rustedandrotten":2ybjl64z said:See Spikes comment.shinji":2ybjl64z said:SPIKE":2ybjl64z said:Shinji,
Would probably be a better investment than Renault HK if they write cars off on test drives! :approve: :rofl:SPIKE":1z6qurpf said:Fly me over and i'll come and take a look!
SPIKE":vg2peb44 said:Fly me over and i'll come and take a look!
