I've been racking my brain (or lack thereof) trying to think what is wrong with my vee based on the following symptoms:
1) takes at least 2 goes to start the car on a cold engine (like left it over nite). This seemed to appear after I replaced the cam belt in July.
2) strong unburnt fuel smell in the cabin and outside the car after the cold start and this maintains for at least around 5-6miles.
3) weird engine noise when you accelerate up starting from about 2.8k to around 3.5k rpm and it subsides when it goes past 4k. The sound is kinda like when you caught yourself in too high of a gear and in low engine speed. This sounds also occurs when the engine is at normal operating temperature.
4) fuel economy has been bad and I have only been driving around in dense traffic, as you do in urban region of Hong Kong. I'm getting around 13mpg to 15mpg [smilie=icon_eek.gif]
I'm thinking along the lines of the fuel pump, fuel pressure regulator or the filter. Am I on the right track?
Hope you guys can shed some more light on it. Thanks in advance.
