I've no idea to be honest but if it finally gets done I will know for certain because it will be corner weighted during setup.
I will elaborate a little more on my expectations though with regards the engine which may cause some debate because in doing so I'll be unable to avoid expressing some contentious opinions so here goes:
So as we know the Phase 1 version of the v6 had a stated power of 230bhp with anecdotal evidence suggesting that once packaged in the car it actually produced something around the 220bhp mark. This is pretty understandable given that Renaults' figures would have come from an engine on a dyno where considerations such as packaging, airflow and air temperature, having the AC turned on or the stereo turned up etc would not be a factor.
The Trophy engines had more "engineering" thrown at them, ran Magnetti management where the focus was on performance and not on getting value for money from 95 ron petrol. The heads were different, induction and exhaust was completely different - twin TBs, much better plenum design due to not needing to meet with certain packaging constraints imposed in the road car, no catalytic converters, different CAM profiles (both inlet and exhaust), different inlet ports and a lighter flywheel. There were probably other differences but that's enough for now.
With these changes the Trophy's made 280bhp so a 50bhp uplift on the production engine which is very significant (say around +20%) given we're talking NA here - so on my engine the changes are broadly similar: multiple TBs using the Trophy plenum, Trophy spec inlet and exhaust cams, custom pistons to lift CR, lighter flywheel and 3rd party management - my expectation is 280ish and that's it.
I'm being realistic here - I have a problem believing that 3rd party management + improved exhaust = +300bhp which would represent a 50bhp uplift over a Ph2 engines' stated output which dont' forget is already apparently delivering a +20bhp uplift over the original engine due to revised induction and some other changes. I get asked the question about how much power quite often and I know some people will be surprised that I'm not claiming it's going to be 330bhp and I'll be looking like JC driving an Arial Atom everytime I go to the shops in the car but my opinion is based on a few things:
1) Look at what the Trophy cars actually made and understand that this was with a lot more engineering and an understanding that they were built to race and not survive 120k miles day to day driving with 20,000 mile service intervals
2) Does it sound likely that Renault designed an engine with so many inherent design flaws that finding an additional 50bhp is just a matter of changing the ECU and bolting on a few bits and some shiny pipes?
3) There were later versions of the the trophy engine and I know a team that were running an engine purporting to deliver something towards the high end of 380bhp - it never finished a race and broke down continously and beared little resemblance to the original engine by that point
To expand on what those changes are on my car just so you get a sense of what I mean by "considerable engineering":
1) Completely re-desgined inlet using ITBs grafted to the Trophy inlet plenum - custom designed and cut in house
2) Inlet -> Head spacer/mounting plate - custom design designed and cut in house
3) Completely new fuel rail, injectors, fuel system - custom designed and cut in house
4) 4 new cam covers to accomodate revised oil filler mounting point, oil drains and new inlet design - custom designed and cut in house
5) Trophy "spec" inlet and exhaust cams with removal of VVC mechanism requiring new cam pulleys and various custom bungs
6) Re-bored block (slight rebore to address bore wear thought to be due to bore wash)
7) New custom pistons - re-profiled and cut in house
New mains/bearing, rod bolts
9) Extended sump
10) Lightweight flywheel - not lightened a brand new custom cut lightweight flywheel one piece design
11) 3rd party management
Yes all that and a bunch of detail stuff I didn't include and I'm still "only" expecting to hit 280bhp but then I think that's realistic but does demonstrate what I mean about the sort of engineering I think you actually have to do to gain the sort of power gains some are attributing to far, far less.
As I said some of this attitude is down to not believing that Renault/Citreon/Peugeot actually designed such an appalling engine that 50bhp is in there just dying to be let out and also knowing what the Trophy's made alongside of an appreciation of what compromises you make when desiging a race engine and how those compromises simply would not be compatible with most peoples needs from an everyday car.
Obviously there's a part of me that would love to wrong and that if the engine finally bursts into life it's shown to produce 1gigabhp but in reality I think my expectation is realistic and if it's gets close to that point I'll actually be a happy v6 driver.
I also hope that I'm wrong for the sake of others who have, like me, invested time and effort in these cars but again I've got a sneaking feeling that my cynical attitude to claims of pulling the siginificant kinds of power increase out of the existing engine without very significant engineering (as per the Trophy engines or going down thje FI route) is perhaps correct.
