This Easter weekend was to be the first fix for the wiring which basically meant that my plan was to have all the major parts of the loom(s) installed by the end of the weekend. I'd not actually be terminating the loom(s) at any loads at this stage...
First job was to re-visit the mega fuse mounting solution; the mega-fuses provide protection for the dual power cables that feed each Powercell so in my kit there are 4 of them. As you'll have seen in an earlier picture I'd original attached them to the plate which normally provides access to the air conditioner and fan but I now needed to add an extra mega-fuse and also a place to mount a remote switched battery isolator so a new solution was needed.
In the end I used the same solution I'd used for the Mastercell and Powercell; aluminium rails bolted to the front bulkhead using rubber rivnuts. A picture is worth a thousand words so...
[album]1188[/album]
This, I think is a much better solution and still allows me to keep the battery +ve run as short as possible. The extra mega-fuse is to provide power distribution for 3 things which are not under the control of the ISIS system; PAS pump and the 2 radiator fans. The fans will be switched by the ECU and the PAS pump via a switch on the console.
Just a quick note on the preparation of the power feeds you can see in the picture above (labelled Powercell 1-A etc) which should give an idea of where all the time seems to go; Basically the preparation goes like this; install full length cable; find out actual require length and cut appropriately; add braiding, add heatshrink x 2, print and attach label, add another heatshrink, strip 10mm of insulation, crimp on 10-8 battery ring terminal (I have to post a pic of the crimpers you need to use for battery terminals; they're, well, big
), slide the last heatshrink you added down over the crimped connector; slide the other 2 over each end of the braiding and then shrink all heatshrink and the label. That's just for one cable...
The battery isolator was a compromise between the affordability of the standard FIA master switch and the 'how can it cost that" much non affordability of things like the Cartek solid state battery isolators. The key thing is that the isolator is remotely switched so I don't have to run dirty great big battery cables into the cockpit and then back out again. The isolator is turned on or off using simple low current momentary action switches - I'll be mounting these in the small panel on my centre console.
[album]1189[/album]
Next job was to sort out a mistake I'd made with the wiring to the centre console; basically I'd not provided any spare capacity and I'd forgotten about the wiring needed for the wipers so I took out the loom runing to the centre console and then recreated it. This was around a 3 hour job but to be honest it was worth it as I've now got some spare capacity in the loom, the split of the loom from the Mastercell end is now much neater etc so I didn't really mind...
After sorting out the centre console wiring it was time to create the output looms. Each Powercell provides up to 10 outputs which are split across 2 multi-way connectors. Simple enough but I also needed to provide "tell tale" feeds to the DASH which meant some slicing 'n' dicing was required. Taking the sidelights feed as an example the basic process was to cut the feed about 10cm away from the Powercell connector; add a label; add a butt-splice connector complete with a feed to the dash; crimp the connector. Once I'd done this for each tell tale I then braided the loom, heat shrunk the braid and then finally added another heatshrink over the top of the butt splices.
In the picture below the Powercell is the box on the left and you can just see the 2 sub looms that provide the DASH power and tell tales:
[album]1191[/album]
With that done it was time to install the rear Powercell. The length of the pre-supplied parts of the loom meant that the most sensible location was over the aperture where the rear NS speaker would normally be. Fortunately this is one of the few flat bits of metal in the Clio so I was able to simply mount the Powercell (again via rivnuts) directly to the plate:
[album]1192[/album]
Then it was time to do the output looms from the rear Powercell - done in the same way as the front except that one of the looms was divided into 3 groups; one traveling to the rear of the car where I suspect the ECU will be going, another to the rear of he car but containing spare (not assigned) outputs and finally one feed for the fuel pump. The other output loom was simply run straight to the back of the car because it will be responsible for providing power to the rear light clusters.
[album]1193[/album]
Then I ran out of consumables
I now need some more heat shrink, some more braid, some more battery crimp connectors etc so I finished the weekend off by installing the cable tie bases which allowed me to then use releasable cable ties to get the various looms tied into position. This is very much the "first fix" so there'll be intermediate cable ties as well and 2 more looms from the rear to the front of the car.
