ReidarUF
I have a C2J engine from a Super 5 TS I plan to put in my -64 R8. The ingine in stock form is a huge improovement but I plan to convert it to EFI and ITBs. I have found two nice little pairs of bodies from two Kawasaki Vulcan 900 that match the inlet ports perfectly. I will cast the inlets in alumunium.
Anyway I will also build a tubular manifold for it using two Opel/Vauxhall XE manifolds for materials.The C2J share the same manifold gasket as the C1J/Gt turbo so I thought I could buy a premade exhaust flange to save some time. But for some reason Renault have not only ditched the four bottom exhaust studs, but also the material holding them.
There is NO studs for the lower section of the exhaust flange making it rely on clamping force from the inlet. The OE inlet/exhaust is bolted together so quite rigid. But there is still clear that the two middle exhaust ports have been leaking.
The new exhaust manifold will not be bolted together with the new inlet the same way.
I think I will either have to drill 3 or 4 new stud holes in the remaining material(marked with black dots) (scary?)to get enough clamping force, or to let the two bottom inlet bolts be shared with the exhaust. In that case I think I will have to cut the flange from L-profile instead of flat iron to make it rigid enough. There is also a threaded bung in the block just under the two middle exhaust ports that might be used to improove clamping force.
what do you guys think? Have this been done before?
