When i jack the torsion bar mounting bracket up to the chassis (to try and get the bolt through) it wont go far enough to allow me to put the bolt through.
I have tried putting weight in the car, I have also tried strapping the chassis to the lifting jack..
due to the spine orientation, my first attempt was for about 30mm, with the haynes stating a 40mm offset it should be easy for me to get the bolt through with a small 30mm preload?
any ideas?
any ideas?
