few things that need sorting still...
1. prop is rubbing on the exhaust at times
2. hand brake actually doesnt work LOL also feels like something is slightly binding so brakes need working again
3. most of the lights on the instrument panel are shot or have dodgy connection
4. finish installing stereo
5. finish the wiring for the wideband gauge
6. refix wingmirror glass
I couldnt get her up to temperature to test the fans which was worrying, had her idling for 15/20mins and still wasnt past the 1st mark. Must be a super efficient engine LOL.
Right a little update in here as people seem to see it better than the blogs.
Prop shaft is not rubbing anymore, as far as I can make out the adjustment to the exhaust hangers have moved it away sufficiently that it doesn't rub on over run.
The hand brake is now working as it should, the near side caliper is really good but the offside handbrake lever was very weak and traveled 5times the distance before locking the wheel. Took it off and removed the piston, under which there is a screw assembly and at the bottom a race bearing with a one way mechanism. This needed a bloody good clean and reassemble in the correct orientation to comply with the piston slot being vertical. I should have taken pictures to help other members but didn't have my phone on me.. Flapped (another of Dave's specials) the rear disc before refitting, bled the caliper which removed quite a lot of dirty dark crappy fluid. Waiting for it all to bed back in then will recheck the adjustment.
Stereo is in, bloody sub box doesnt quite fit due to the quadra boot being shallow compare to the 2wd
Wideband is in along with my gauge
Wingmirror is sorted for the moment
Need to purchase some little bulbs for the dash illumination as I can only see the odometer and nothing else LOL!
Got a manual boost controller through the post the other week, which needs installing, going to take her up a few PSI.
All starting to come together..
