Nothing hopefully, he shouldnt have failed me on the rear pads, if you cant see it you cant fail it.
As for the track rod ends, I will have the car up in the air tomorrow with original wheels on and see if they have any play.. which I suspect not.
Need to check out the hubs see if the threads are stripped and possibly run a tap through them, or swap them over for some spares.
Will also check out some diamensions and purchase some longer wheel bolts for use with the aftermarket wheels.
Gave her a wash today, pressure washer has stopped working so was back to old hose and sponge. Looks blinging now without the green layer.
