Paint defects a quick lesson
Yesterday I started to flat the shell and doors, the paint is completely flat and displays 2 distinct colours meaning it has been painted, as I started flatting the doors I noticed microblisters as the top layer came off see photo
As you look at the pic the bare metal is obvious , next around this is the Red oxide primer then Grey surfacer primer and finally the dark red topcoat if you look to the left you will see more grey primer and more red, this is the respray. If you look at the edge where the red goes to grey you can see spots which is where the paint has not adhered properly, any adhesion issues must be gone or your new paint is not stuck to the car, so it has to come off. Deep joy..........
Next up a cautionary tale for patina lovers.
The roof was original, thankfully the dodgy respray is only the bottom half (top swage down) it had a few spots on it and a couple of scrapes, but once into the surface the corrosion is much worse than the outside view suggested, once again this means going back to bare metal to find all the corrosion
Patina may be cool in Southern California where the sun has burnt the paint off, but here in Blighty it's the damp that lifts and flakes paint and it's better off all gone, so it can be properly sealed up again
This is the current state of play, then all the replacement panels need the treatment. Good news was only 1 repair found on the drivers doors although there are about a dozen dents needing remedied.
Invisible repair!!!! #roughastoast #rustyraftsRus
More soon........................
