Renault 11 Turbo Phase 2 Restoration
Its took me about a month of on and off reading to get back up to date on this thread !! I picked up where you had had a smash into the rented storage garage Steve :ireful2.gif:
Ive got to say the build looks awesome after the ups and downs you've experienced with it, paint shop let down etc Its going to be epic when its finished :boast.gif::drinks.gif:
Thanks very much @Chris Sadler means a lot for you to say that 👍
I’m hoping she’s going to be a little fighter when she’s done
Been working thru the cooling system over Christmas, hoses cleaned and then placed on the car to check fitment before any hose clips are fitted:
Thanks for Reading 🙂
WOW is the only statement i can respond to that picture with, thats some major attention to detail and a serious inspiration for me, if i can get my bay looking half as good as that i will be happy
Wired the fan in today, together with the fan switch and Anti Perc fan:
I also continue to try & get all the coolant piping all neat and tidy within the engine bay. It’s crazy how when you spend time looking at everything, you can really see where Renault intended everything to go and all the clip locations soon make themselves visible!
Of the coolant hoses I am happy with, I’m also starting to secure with my collection of OE Norma Clic-R fastenings: #oenerd
Thank you for Reading 🙂
Loads is little progress on the 11 Turbo engine bay continues. Dug out 2 of the radiator air guide shrouds and after giving them a quick lick of paint:
They were fitted on the right hand side:
And underneath the Radiator:
I then fitted nearly every engine bay hose and clamped them in place with the Norma Cobra clamps:
Now I had the oil cooling lines connected to the radiator, I thought I’d whip the spark plugs out and “prime” the oil around the engine.
Battery connected, key turned and....
FUCK ALL 🤬
Fuckpissarsebollockswankshitbags!!! No doubt there’s a connection I’ve missed somewhere...
Just had a look back through, great looking engine bay. I was just looking at my projects over the new year , and found myself saying ( in my head of course, I not completely mad ) what would Steve do with this . The standard is high as always . Sorry to hear she wouldn’t turn over it will be something silly it always is .
I had the same when built my 197, turns out I'd somehow blown the starter fuse
No fuse on the old 11. It's a very simple power feed in to the ign barrel, out of the barrel through a series of multiplugs down to the spade on the starter, then the starter earths through the casing.
>Is there power to the ign barrel?
>if so, is there power out of the ign barrel on the "start" position?
>If so test for 12v on starter kick at the spade on the starter, if you have it work backwards and find the break
>If you do have 12v at the spade check the engine earths are connected and not fouled with paint
>If you have power at the spade and good earths then short out the starter terminal to the battery, see if it spins, if not its probably the starter is shot.
