Doesn't matter how much space you have, you'll always need more..just need another garage now!!
A shrinker/stretcher makes this kind of job a lot easier.Got out there today and made the lower internal wheel arch. It turned out ok.
Cut a new piece of lat for it!
Had a look at the other side for comparison, and noticed just how bad the drivers side is!
So I got to work making a cardboard template!
Then reversed it and laid it into the existing panel to ensure it fits.
And then tried the whole thing on the car!!
I then clamped the old panel on to the new flat and drew around it!
I then added 15mm all around as the returns. I plan to trim these off later to suit.
I then trimmed it off and began bending and hammering the metal!!View attachment 152362
And hammering, and bending!!!
Once it was roughly the same shape as the original, I began hammering the returns on the panel, This caused me some issues - as I turned them up, it straightened out all my hard work hammering!!!
Gave it a trial fit just to check!
I noticed that there was still some remnants of the rusted old piece so I got the file out and filed them off!View attachment 152368
A much better fit! I had to put some cuts into the returns to get the thing to bend again, could do with some proper tools for this really! Once I had dressed it in and got it exactly where I wanted it, I took it back to the bench and dropped some welds on to the cuts, which has done the trick!
End result, I'm quite happy with that!!
Thanks for reading!!
Funnily enough I ordered one last night!!A shrinker/stretcher makes this kind of job a lot easier.
If you had looked at my R9 Turbo thread there is a detailed rear axle strip and rebuild right here on TurboRenaultThe wife did ask why I was watching Russians that late at night!!
Gasket had gone too looking at the carbon staining on the gasket face, get the flange checked for straightness after its welded up.But the manifold is cracked!!
Thanks for the info @clarky_gtt Ill get on the hot for a decent stock manifold!I'd bin that Manifold, stock one is solid!
