Got a couple of hours spare today, so got out in to the garage! I noticed that the front end arm that I cleaned up last time has started to surface rust so I made the replacement panel, spot welded the holes, ground them down and rust treated the whole arm. I then had another go at that bloody passenger door hinge pin!!! Got it out this time and managed not to destroy the welded bracket....bonus.
2 weeks surface rust/ flash rust.....whatever its called..still bloody rust!!
And now for making that replacement panel with no specialist tools!!
I flattened the existing panel and drew around it, I then took some measurements and marked them on the new sheet.
I got a bit of scrap angle and gripped the sheet to my worktop to make the bends before cutting to size.
I then got a pile of rags and marked the raised corner section on the back of the sheet, and began to hammer it down into the pile of rags, using my lines as a guide!
Its starting to take shape!
Almost there!!
I then marked it from behind and trimmed off the excess!
I'm quite happy with the result! Its not perfect, but its better than what was there!
I then cleaned up the are with the grinder and welded the holes that I made drilling the spot welds out. I then ground it all down nice and smooth, and then applied rust eater to the whole area!
I Then decided to have another go at the dreaded door hinge pin! and after a few drill bits nd a fair bit of swearing, the remainder of the door hinge pin came out in a cloud of rust! RESULT!!
Thats all for today! I hope this is interesting for you guys. Any advice and tips as always is very welcome, and if anyone knows where I can get some replacement panels, floor front and back, cills inner and outer, maybe a drivers side rear quarter...please let me know.
Thanks for reading!
