She mixing the Concrete for your new boots already..!!?I don't know, I may have pushed it too far! If there are no further posts, you know why!!!![]()
Its easier to ask forgiveness, than to ask permissionI don't know, I may have pushed it too far! If there are no further posts, you know why!!!![]()
If anyone has one of those Tee pieces, please let me know!!
Thanks for reading guys!
Thanks @Big Steve - Raider, The T Piece approx 11mm x 4mm x 11mm internal Dimension.Measure the old one up. Quick google finds this:
Eberspacher Espar Heater Fuel Pipe Fitting T Piece 8/8/6mm (26231151) | eBay
Eberspacher Fuel T-Piece 8X6X8mm. Genuine Eberspacher Part. Eberspacher Part Number.www.ebay.co.uk
Or this:
8mm-4mm-8mm Airline Reducing T Piece (3pk)
The Kockney Koi 8mm-4mm-8mm Airline Reducing T Piece is ideal for spurring smaller 4mm airlines from a larger 8mm airline run. Supplied as a pack of 3, these airline connectors are easy to use with airline simply pushing externally over the barbed connections.www.pond-planet.co.uk
Next challenge please..Thanks @Big Steve - Raider, The T Piece approx 11mm x 4mm x 11mm internal Dimension.
Thanks Steve, bought via your link!
Hi Dave, I did exactly the same, after I had cleaned the old gunky stuff off! I put grease on both ends, not sure if you are supposed to, but its on there now!!Looks fab. I threw some moly grease on my rack teeth, it looked a bit dry.
Same!I put grease on both ends, not sure if you are supposed to, but its on there now!!
