7700 765 935 engine mount ?13.28 Qty. 1
7700 766 247 engine mounting ?5.48 Qty. 1
7700 766 269 LHF bumper trim ?2.98 Qty. 1
7700 766 270 RHF bumper trim ?2.98 Qty. 1
7700 766 369 HRW switch ?6.90 Qty. 1
7700 766 371 fog switch ?5.48 Qty. 1
7700 766 374 RH window switch ?5.72 Qty. 1
7700 767 436 RHF h/l moulding ?8.70 Qty. 2
7700 767 475 4 spd gear lever knob ?5.50 Qty. 1
7700 767 655 LHF wing moulding ?3.13 Qty. 1
7700 767 656 gear lever knob 1721, 1870, 1965cc ?3.05 Qty. 4
7700 767 658 gear lever knob 1995, 2068cc ?3.05 Qty. 1
7700 767 822 bonnet catch ?3.47 Qty. 1
7700 767 833 door handle ?4.31 Qty. 1
7700 767 837 fuel flap rod ?1.80 Qty. 2
7700 768 044 engine mount ?2.23 Qty. 2
7700 768 122 steering rack gaitor ?4.27 Qty. 1
7700 768 591 oil switch ?5.48 Qty. 1
7700 768 717 plug ?0.67 Qty. 1
7700 769 026 radiator clip ?0.43 Qty. 1
7700 769 101 LHF door trim ?7.05 Qty. 1
7700 769 226 A/R bar bush ?1.57 Qty. 1
7700 769 313 rear wipe switch ?7.60 Qty. 2
7700 770 021 rear side window rubber ?0.39 Qty. 1
7700 770 025 LHF window rubber ?6.27 Qty. 1
7700 770 655 LHF wing moulding ?3.53 Qty. 1
7700 770 656 RHF wing moulding ?3.53 Qty. 1
7700 770 658 RHF wing moulding ?3.53 Qty. 1
7700 770 662 RH door moulding (482,E,J->30572) ?8.23 Qty. 1
7700 770 972 catch ?1.57 Qty. 1
7700 770 982 rad bracket ?0.90 Qty. 1
7700 771 309 door handle base ?0.67 Qty. 2
7700 771 682 rad shield ?9.01 Qty. 1
7700 772 177 LH rear bumper trim ?8.23 Qty. 2
7700 772 178 RH rear bumper trim ?8.23 Qty. 3
7700 772 181 LH front bumper trim ?8.23 Qty. 1
7700 772 182 RH front bumper trim ?8.23 Qty. 1
7700 772 392 rear quarter seal [saloon] ?8.23 Qty. 1
7700 772 695 ash tray ?7.97 Qty. 1
7700 772 742 heater air duct ?4.70 Qty. 1
7700 772 996 grey,rear seatbelt (59.50) ?38.19 Qty. 1
7700 773 119 brown parcel shelf catch ?2.86 Qty. 2
7700 773 245 A/R bar bush ?1.88 Qty. 2
7700 773 620 g'box mount ?18.21 Qty. 1
7700 773 631 front spoiler kit ?18.80 Qty. 1
7700 774 269 power steering pipe ?2.70 Qty. 1
7700 775 641 lever ?1.80 Qty. 1
7700 776 531 LHR seat recline handle-grey ?0.80 Qty. 1
7700 776 536 seat handle ?0.90 Qty. 2
7700 776 836 ? ?0.00 Qty.
7700 777 440 door moulding ?3.53 Qty. 1
7700 777 518 LHF door seal ?9.01 Qty. 2
7700 777 684 thermosensor ?11.44 Qty. 1
7700 777 685 rad. temp switch [87.50] ?11.44 Qty. 1
7700 777 685 thermosensor ?11.44 Qty. 1
7700 778 035 rubber seal strip ?1.18 Qty. 1
7700 780 016 throttle cable ?4.11 Qty. 1
7700 781 565 LHF door moulding ?15.78 Qty. 1
7700 781 566 RHF door moulding (482,E,J 30573->4/89) ?15.78 Qty. 1
7700 781 572 RHR door moulding ?12.53 Qty. 1
7700 781 815 LHF wing trim ?13.90 Qty. 3
7700 782 700 RHR quarter moulding [wing trim?] ?3.53 Qty. 2
7700 782 769 LHR door moulding ?15.82 Qty. 1
7700 784 233 door hinge plate ?2.35 Qty. 1
7700 784 431 ABS badge ?2.74 Qty. 2
7700 785 457 w/w switch ?4.73 Qty. 1
7700 785 820 RH bulkhead plastic ?3.13 Qty. 4
7700 786 182 saloon fuel tank support ?6.27 Qty. 1
7700 786 466 temp sender ?7.40 Qty. 2
7700 787 671 grille ?4.31 Qty. 1
7700 788 663 gear lever knob 1995, 2068cc ?3.05 Qty. 1
7700 789 202 LHF wing trim (1721cc?) ?4.03 Qty. 1
7700 789 237 LHR wing trim moulding ?3.53 Qty. 2
7700 789 923 LHR wing trim ?1.96 Qty. 1
7700 790 061 grille ?3.13 Qty. 1
7700 791 103 rear bumper bracket ?2.00 Qty. 1
7700 791 104 rear bumper bracket ?2.00 Qty. 1
7700 794 686 wash/wipe switch ?4.73 Qty. 1
7700 795 160 sh abs cup ?1.20 Qty. 2
7700 795 162 shock absorber cover ?3.50 Qty. 2
7700 795 749 s'absorber wedge ?6.30 Qty. 1
7700 796 462 moulding end ?0.50 Qty. 1
7700 796 587 rear silencer ?23.50 Qty. 1
7700 797 177 exhaust box ?18.88 Qty. 1
7700 802 653 GT spoiler ?18.80 Qty. 1
7700 805 116 g'lever knob ?6.19 Qty. 1
7700 809 128 cover ?1.18 Qty. 1
7700 817 816 sunroof switch ?5.56 Qty. 1
7700 823 980 1.9dT badge ?3.53 Qty. 1
7700 824 486 headlamp adjust cable ?18.02 Qty. 1
7700 827 696 LHF door moulding ?10.97 Qty. 2
7700 827 703 RHR door moulding ?12.30 Qty. 1
7700 827 704 LHR moulding ?3.91 Qty. 1
7700 853 837 pressure valve ?7.40 Qty. 1
7700 853 902 inlet manifold seal ?0.48 Qty. 2
7700 854 647 water pump gasket ?0.43 Qty. 1
7700 854 655 cyl head seal ?0.80 Qty. 1
7700 857 060 seal ?0.97 Qty. 4
7700 860 407 pipe assembly ?10.22 Qty. 1
7700 863 737 auto gearbox sump seal ?7.44 Qty. 1
7700 863 738 auto gearbox sump ?29.77 Qty. 1
7700 993 580 ? ?0.00 Qty. 1
7701 029 909 h/lamp terminal ?2.20 Qty. 1
7701 032 019 Signal' rear bulb holder ?3.37 Qty. 1
7701 032 022 rear light connector ?4.27 Qty. 1
7701 032 120 LHFlock ?5.88 Qty. 1
7701 032 244 blank key ?1.18 Qty. 6
7701 032 326 temp. gauge ?9.33 Qty. 1
7701 032 330 speedo ?37.99 Qty. 1
7701 032 366 horn bracket ?2.74 Qty. 1
7701 032 719 clip ?0.80 Qty. 1
7701 032 894 rear bulb holder ?3.40 Qty. 2
7701 032 897 bulb holder ?3.43 Qty. 1
7701 032 926 plastic screw 5x12 ?0.94 Qty. 1
7701 033 191 rear seat strap ?5.90 Qty. 1
7701 033 789 tailgate lock ?14.00 Qty. 1
7701 034 134 LH headlamp ?30.00 Qty. 1
7701 034 321 LHF lens ?5.50 Qty. 1
7701 034 322 solenoid switch ?4.70 Qty. 1
7701 034 489 door lock motor ?16.10 Qty. 3
7701 037 744 injector ?7.75 Qty. 1
7701 201 640 Interior mirror bracket ?1.60 Qty. 1
7701 201 719 brake adjuster kit ?8.20 Qty. 1
7701 201 830 auto g'box cable ?45.80 Qty. 1
7701 202 214 m/cyl kit ?32.50 Qty. 1
7701 202 698 rear quarter rubbers ?5.90 Qty. 1
7701 202 805 ABS brake motor ?86.60 Qty. 1
7701 202 869 seat adjust kit ?1.97 Qty. 1
7701 202 870 seat release kit ?1.96 Qty. 1
7701 202 871 seat release kit ?1.96 Qty. 1
7701 203 118 Ducellier distributor cap & rotor ?7.21 Qty. 1
7701 203 120 P.A.S. pump kit ?2.62 Qty. 2
7701 203 516 rear shelf cords ?2.15 Qty. 1
7701 348 374 thermostat 86 deg C ?4.70 Qty. 2
7701 348 822 2.95mm crankshaft thrust washer ?3.60 Qty. 2
7701 349 159 con rod bearings ?12.49 Qty. 1
7701 349 572 big-end shell set ?10.60 Qty. 1
7701 349 573 main bearing set ?16.50 Qty. 1
7701 349 594 alt belt 10x1004mm 2ltr ?2.40 Qty. 6
7701 349 780 Bendix brake shoes [1 wheel only] ?5.90 Qty. 1
7701 349 794 oil switch ?4.00 Qty. 1
7701 349 893 horn bracket ?0.60 Qty. 1
7701 366 142 door mirror RH/LHD ?19.60 Qty. 1
7701 366 146 LH electric mirror ?29.00 Qty. 1
7701 366 151 int lamp ?7.10 Qty. 1
7701 366 487 TXI badge ?3.13 Qty. 1
7701 366 492 int. lamp ?6.66 Qty. 1
7701 366 975 grey front seat belt (59.30) ?37.80 Qty. 2
7701 386 200 dark grey rear mats ?10.20 Qty. 1
7701 388 268 badge ?4.67 Qty. 7
7701 418 167 front mud flaps ?5.00 Qty. 9
7701 418 168 rear mudflaps ?5.00 Qty. 3
7701 422 030 clips (pkt 10) ?1.49 Qty. 1
7701 423 159 ultrasonic alarm ?22.70 Qty. 1
7701 423 160 electronic siren ?8.60 Qty. 1
7701 423 279 electronic siren ?27.80 Qty. 1
7701 423 283 sun roof module ?8.20 Qty. 1
7701 423 284 window module ?14.90 Qty. 1
7701 423 492 alarm module ?10.60 Qty. 1
7701 462 101 RH boot kit 79mm ?7.79 Qty. 1
7701 462 182 front lower ball joint ?11.67 Qty. 2
7701 462 843 thrust bearing ?4.23 Qty. 1
7701 463 081 inlet valve set ?26.24 Qty. 1
7701 464 066 1st,2nd synchro ?65.80 Qty. 1
7701 464 105 diff. ring kit ?1.58 Qty. 1
7701 464 939 switch & cable ?25.65 Qty. 1
7701 465 217 gear lever ?16.80 Qty. 1
7701 466 172 shaft inner boot ?7.79 Qty. 2
7701 631 034 RH steering arm ?27.81 Qty. 1
7701 768 122 strg rack boot ?4.78 Qty. 1
7701 987 783 engine loom ?10.87 Qty. 1
7701 993 580 LH door loom ?10.77 Qty. 1
7703 027 127 stud 5x.070 ?0.18 Qty. 1
7703 046 036 clip ?0.19 Qty. 2
7703 065 054 auto gearbox seal ?0.00 Qty.
7703 065 067 cyl block joint ?0.43 Qty. 1
7703 066 045 front hub circlip ?0.31 Qty. 2
7703 067 080 cotter pin ?0.12 Qty. 4
7703 068 011 cotter pin ?0.20 Qty. 1
7703 072 004 rivets 4x12.5 ?0.12 Qty. 1
7703 072 047 rivet ?0.18 Qty. 10
7703 072 126 rivet ?0.18 Qty. 12
7703 072 239 plastic seat rivet ?0.11 Qty. 10
7703 073 212 sleeve ?1.57 Qty. 1
7703 074 255 plug ?0.16 Qty. 9
7703 075 031 plug ?0.43 Qty. 1
7703 075 033 sump bolt ?0.38 Qty. 1
7703 075 053 cap ?0.69 Qty. 1
7703 075 065 core plug 14x7 ?0.71 Qty. 1
7703 075 106 cyl head plug 14x125 ?3.72 Qty. 1
7703 075 121 plug 12x175 ?0.37 Qty. 1
7703 079 537 clip ?0.55 Qty. 1
7703 081 096 grey carpet plug ?0.78 Qty. 2
7703 087 106 diff oil seal 26x42x17 ?2.27 Qty. 2
7703 087 142 hub seal ?2.27 Qty. 1
7703 090 209 wheel bearing->7703 090 358 ?6.27 Qty. 1
7704 002 578 bush ?1.53 Qty. 2
7705 002 056 12x18 grommet ?0.30 Qty. 1
7705 030 088 T' piece (2way union) ?2.70 Qty. 1
7705 126 540 oil vapour tube ?1.53 Qty. 1
7711 079 693 braking system manual ?2.00 Qty. 1
7711 080 057 handbook 6/87 ?3.00 Qty. 1
7711 080 255 1986 wiring supplement ?1.80 Qty. 1
7711 080 361 diesel manual ?2.00 Qty. 1
7711 080 424 injection diagnostic manual ?2.00 Qty. 1
7711 084 496 handbook 6/89 ?3.00 Qty. 1
7711 086 412 0wners handbook 4/89 ?0.80 Qty. 5
7711 086 482 1989 wiring ?2.00 Qty. 1
7711 090 419 handbook 8/91 ?3.00 Qty. 1
7711 091 081 handbook 12/91 ?3.00 Qty. 1
7711 130 003 clutch kit 180mm ?29.38 Qty. 1
7750 705 342 chassis bracket ?3.13 Qty. 1
