Project Race-19 16V
Ronald16V
Project Race-19 ITB'd 2.0 16V
Started in 2006 with a trackday @ Circuit Zandvoort in The Netherlands with my '92 Renault 19 16V
- 1.8 16V F7P 704
- Wiechers Sport rollcage
- Koni Yellow shocks
- Toyo R888 195/50R15 GG Tires
- 4-2-1 Devil header
- Clio RS 182 brakes at the front with Carbone Lorraine RC6 pads (rear: original calipers with CL RC6 pads)
- Goodridge brakelines with ATE Racing Blue brakefluid
- Laguna 2.0 16V 23.8mm master brakecilinder
- Sparco Sprint seats with Sabelt belts
This was at the Renault Tuning Club meeting in the Netherlands. on 17" wheels with street tires
Interior
Trackday @ Circuit Park Zandvoort NL
@ Nürburgring Nordschleife Germany, about 200laps with the 19 there now :D
@ Slalom day from Wimedo at Lelystad (NL)
That was the last day the circuit with the 19, time to fix it up now. bad engine (valveseals/pistonrings, heavy smoking..) and a very rusty bottom
Building up a new Engine:
- F7P 722 1.8 bored to 82,70m
- F8Q 1.9D crankshaft
- Williams pistons with some CNC work to fit the bigger valves
- Williams rods
- Some headwork and flattened 0.8mm to make 1:11,3 compression
- Peugeot 2.0 16V inletvalves (bigger than Williams and bigger than Megane)
- CatCams valvesprings
- KentCams 1605 304 degree camshafts with mechanical followers
- KentCams adjustable camgears
- Renault 21Turbo injectors
- lightened flywheel
- Jenvey 45mm ITB's
- KDFi stand-alone management
Peugeot 2.0 16V Valve's
Jenvey ITB's
with Kent Cams adjustable wheels
After some welding, some painting does the job
Mounted the dash.
Mounting the 2.0 to testfit it. no gearbox yet, searching for a Ronald-Proof gearbox. :p
Rollcage mounted
Taking some expensive Cup Megane suspension shit.
And a RenaultSport adjustable brakedistributor for in the car
Topmounts with uniballs, its an example. the Megane topmounts doesn't fit properly so we make it custom.
All connections are uniballs and it have a roll centre correction.
With the Megane Cup suspension, 3cm wider by side is very huge. :D
Mudflaps? Anyone? :eek::lol::p
Need some work to fit. :roll:
Cup vs. original comparison....
Here some movie's of it with the F7P in it on several tracks in NL
http://www.youtube.com/watch?v=V9T_kunZTCY
Circuit Park Zandvoort NL (Wet)
http://www.vimeo.com/16446306
Slalom Ter Apel NL (Car is to long for it, but it's fun :))
http://www.youtube.com/watch?v=tjmXi-ppKHA
http://www.youtube.com/watch?v=EKWgNvlfxL8
Awesome set of track photos :)
One thing though.... where the F**K did you get this from?
I needed a new one of that type for my 11 Turbo and could. not. find. one.
The adjustable brake distributor comes also from a RenaultSport Cup-Megane. We break a good '98 Cup-Megane from the Dutch Renault Megane Cup for the parts. My mate have the engine and some dash parts for his Trackday-Megane and sold the Sadev seqential gearbox and the other parts.
What about the mounting of the cup-shocks on the rear? we mount it same as the
Megane, need some welding and some technical issues. We replace the rear axle for a Megane Cup-axle that has no torsion bars. And the height of the car can be adjusted with the shocks. Its fully independed :)
I have a update ready for uploading but first thing is to fix the broken links of the picture's.
One moment please :D
EDIT: Added some pictures and removed some links because i lost the pictures on my harddisk. :(
Found a gearbox, its a Megane F7R JC5 gearbox. The plan is to reinforce the circlip that holds the diff sunwheel with a bolted plate. more about that soon.
Mounted the Megane Cup suspension on the front and rear. little problems with fitting the fenders but thats a problem for later.
First some welding in the engine room..
set
Sanding the engineroom
Welding in the wheelarches
New sealant and paint. :)
Custom made topmounts with uniballs, the Megane Cup topmounts doesn't fit
Mounted brakebooster and master-brakecilinder and Megane-Cup pedalbox with adjustable clutch-cable.
Mounted the Megane Cup rear axle with Clio II RS Cup axle stab's with camber plates, its a little bit wide but it fits perfect :D
Megane Cup subframe mounted
With a widened suspension the old steering would't fit, so i builded some custom work with a R19 16V steering-rack with Clio II RS Cup arms and Megane Cup ends
Behind the bodyprotection.. didn't see the rust, so i started again with welding. :roll::D
New one inside
New one outside, maked it a little bit shorter to create more space between the road.
Left side ready
Bought new brake's: AP 4pot calipers produced for RenaultSport
With Tarox 280mm disc's
With 10mm spacer it wil fit.. but thats a bigger problem with the fenders. but thats for later :p
Enough for now, much work to do now. i hope you like it. :D
Really nice work Ronald.
Can you please use the [break] tags to add your updates onto a new page, rather than put them in the comments section?
That's an awsome build, it pulls very well for a non turbo'd car. What sort of power does it put out? I would love to do an engine build like that for my 19, maybe one day....
