I am about to refit the oil sump (engine on the car), best method would be Hayns guide? Using sealant and avoid the "Shaded area" (see photo)? I also have the cork seal...
Any advise here? I might also do the timing cover seal and small rubber seal
As already mentioned thin layer in shaded area with oem seals and use a quality sealant how I used to do it and worked fine, make sure all surfaces are nice and clean / dry also
Never seen the one piece gasket @Big Steve - Raider but looks a good option, are you still using a thin layer of sealant with it?
