My 11 auto to turbo
Leefpe
Hi all name lee I have a auto 11 witch I’m looking to turbo I have a full 5 gt turbo to rob of its engine and every think else needed . Just looking for more info on other bits il need? I know I need to get 11/19 manual driveshafts but is there any more bits il need of a 11 turbo ?? Or will most of the 5 turbo stuff be fine . I’m going to use the 5 subframe and from hubs and arms if possible so I can run better front suspension and front brakes .
like said any more info be grate !! And also parts . Looking for a turbo front and back bumper and others little turbo trim/spec bit 865371F6-9313-467B-96FF-49E9382609E1.webp2BFCB5C6-62F6-499D-9B5B-5D1E2B56F44F.webp
I don't think you need to change the subframe, it should be the same. Use the GT Turbo stub axle carriers complete with brakes, then you would ideally want 9/11 Turbo struts.
I'd also go for a 9/11 Turbo rear axle with the 4-bar torsion beam unless youre is 4-bar already, with Turbo shocks.
You'll need the complete engine, box, engine loom & AEI, the GT Turbo clocks do work straight swap to a 9/11 too but i'm not sure on the Auto 11 wiring, ideally you want the 9/11 Turbo dash & chassis rail looms and fuse panel too to make sure everything in the cluster works. Also you'll want the whole fuel feed system from the GT which is also controlled by a relay on the fuse panel.
Thanks for the info matey I’m il sorce the bits of the 5 as for the 9/11 loom bits that’s going be fun to find
