Marks RX7 - lets break a rotary.
I’ve started to strip the engine bay to remove engine but before I do I need my friend Mark to come and measure up for new loom.
Meanwhile I’ve bought a few more little things.
An additional 3 port MAC valve as will run two for boost control. 2 x 3D printed MAC valve brackets. 2 x Syvecs switches to move between various MAP settings when tuned and a 3D printed dash bracket for the Syvecs D4 dash for when I can afford one.
D9227C0C-01CB-4674-A526-B11AE2FCB555.webpBF264E05-6244-4C4E-AF59-33FD3FBCAF4D.webp9B064F52-7593-403D-835B-53E1EC2247E7.webp3ECC06E1-53A0-445F-8BBF-42A6A8C5EFA0.webpF58FD710-6FC0-456D-A545-5E96BDD77DBE.webp
To help keep the costs down a tad before I move to a more modern turbo I’ve decided to keep the HX50 turbo but I’ve sent it off to USA to have the compressor wheel changed from a 67mm to a 76mm meaning I’ll have a sizeable 77/86 with approx 1.3 AR for all the turbine flow. I’d guess capable of 800 on a rotary.
Next step get Mark started on loom, it’s very substantial compared to current loom, this is probably my biggest hurdle.
I then need to invest in a new ignition system - going to use M&W set up.
I’m waiting on an extremely swanky sump from Winchester - it’s custom made and still waiting for him to start fabrication.
Then I need to find a capable fabricator to make me an upper inlet - this is the inspiration.
After 40 days in customs and a £300 bill the turbo finally arrived.
AD7FCBBD-6124-49B7-8483-5B90D6AB2AAB.webp9AA8EFDD-8CA2-4E8B-B8E3-84F2F2E4ABF1.webp65E73D52-C23D-41A5-83E5-767219B879D3.webp9D0E568B-895B-4666-B49C-F5C616AADF5F.webp
The loom will be started next week with any luck. Still waiting on custom sump, it’s been 4 months now but I’m led to believe it won’t be too much longer.
The lower inlet manifold has been amended slightly to allow a bit more clearance.
I’ve started purchasing the water/meth kit and slightly larger injectors. Awaiting delivery from Aus.
Will look something like this but won’t be using push fit lines.
Here’s an Evo example.
Hoping for a Feb/March engine install.
I’ve deleted Facebook and Instagram recently so just the updates on here moving forward.
