preRS Clio M9 Clio 16v -no not slamber related 🤣
Exhaust fabrication up next. I was kindly donated the manifold and downpipe by coops, however half the downpipe was missing. Luckily the easier part to make i ordered a selection of pipe bends and some flanges to make the missing part and a decat. Luckily for me I have a friend who is awesome at welding.
17627711-F5E9-440F-B35F-5BFBC8DD1B5D.webpCA95D684-2DCF-467D-B752-464508124D9B.webp2F78B914-100E-4E1D-AAF1-DA1D42C5BE47.webp8FBAF8D6-409B-45F2-BE05-C4D93F33DAB2.webpAEAB4518-1E1A-4613-985F-C33CD9B06BFA.webp21C8D54A-D317-43A1-B60E-D8999DF4DE92.webpFCB5FE04-7758-43B4-9C1E-DFFBF5B37D33.webpA5724CBF-D64B-4471-A99F-A2FCFAB3EF4A.webpD746F729-1BAC-4D9F-934B-3BE08C2257DE.webp
Next on the list was to sort out the cooling circuit for the turbo. I didn’t want to have it on the engine circuit for a few reasons. The main one being just to be a little different.
I used a lightly modified 206 header tank and bracket fixed to the bulkhead below the Clios engine one and used a bosch auxiliary water pump, like the Clios own standard aux pump. Wired to a relay to come on with ignition. Tried to get it to only run with the engine but I struggled to find an easy wire to tap in to. The rad is a charge cooler size / type. Not many pics of these parts though.
19C05811-55A2-46CF-AE33-FA9534600AF1.webpA8822D4A-5640-47C2-B420-A65600A59FFE.webpD6C9F752-2EC1-4DFB-976D-E9D4F20DEB3D.webp
Next up was the battery relocation. Originally I wanted it kept under the bonnet, but with the new additional coolant pipes and tank there was no room for an air filter to fit in. I bought a crimping tool, a junction box, extra cable to extend the stock loom and robbed a battery cable from an E90 330d. Still haven’t final fitted the battery box yet. The battery is just sat in the boot at the moment.
84B5070C-4496-48A0-8CA3-6B7EFAD0FE37.webp8ABC0C34-3AF1-4D37-8A40-6972B383CFE7.webp9F49E862-BBF9-4EEE-B859-419AAF226F80.webp
I started the car and it idled really high. I could not for the life of me find a reason why, there was no air leaks anywhere. Last thing to check was the throttle body. Needless to say it was f**ked. It’s a R19 16v body and who ever played with it mullered it. The butterfly’s were not seating properly and had been ground down to a sharp edge. They weren’t even round any more. Luckily I had a spare Clio 16v throttle body I could pinch the butterfly’s from. Once that was sorted it idled perfect. 7817B622-F506-49F4-83B5-40CF21FF5D13.webp86264F6B-FD3B-4294-B4FF-4086544E9257.webp410EF8AE-F098-4FF7-AAAD-019409A8F023.webp
Whislt the car was up on the ramp I noticed bit of rust on the sills. Yeah, that turned in to a lot of rust 😫😫. The arches had a fair bit of bubbling but the underlying metal was not too bad. Oh and a random rust patch on the rear 1/4. Same story both sides, just the passenger side is a tad worse. 5E84757A-8C45-4996-921B-FB72564D0811.webp75BDDC32-D8B9-457E-9B8A-DCCF6617E5C4.webp210C6F69-4C4B-4888-9F33-198A393C0B8E.webp
