LS1 to UN1 DeLorean
I do believe that the PRV V6 was originally designed as a V8 hence its wide V and odd fire on the early versions, so as the piece reports the DeLoren has an engine that should of had.
The UN1 is very popular in kit cars. You can adapt it to many engines, including a Cosworth YB.
Any adapter-plates / Kits available that you know of? Imagine a Corvette powered 21;-)
Whilst browsing a bit, I even found DaveL485 in a Kitcar-Forum (about GT40's) ;-). Kitcars are really cool, but not worth to try to get it streetlegal in Luxembourg. I have an unfinished project since 1997, a left hand-drive Gemini Kitcar, PRV V6 mated to a Peugeot 5 speed gearbox (that was pretty much easy, just 2 small DIY brackets) sits in my Garage for nearly 20 years now...
As far as I know, the PRV was designed as a V8 but they cut 2 cylinders because of the oil-crisis in the 70s.
I've got a whole new 1 piece bell housing to a cosworth engine.
As used in RS200 kit cars (that's essentially what mine is in a Renault 5 shell.)
