Turbell
This is the most sensible explanation, I can see that the bush clips may have broke a while back, during the time selector was stiff, bush has been 'walking' it's way out, finally dropped out, the left/right pivot no longer limiting fore/aft travel, the worn ball clips have let go , hence double fault.Damage prob done when selector was stiff and its finally given up. The stiff selector puts loads of stress on the rest of the components, ive heard of a few cables breaking. Bosh a new set of oem cables on from kam whilst in the area.
Timing is unfortunate for dealer.
That explanation will keep me sane.
Gear mech is at Turb-elderest , he's turning a bush to fit onto existing bush to bring length out of mech case, then I'll put an M8 bolt through it with penny washers and a plain nut locked up to a nyloc , so it's secure without crushing up the pivot and causing binding.
When theory is in practice and sound, I'll get Turbaby to order cables from KAM
