Norwich Nick
Just made me think of my gtt gearbox which has been dry stored for, “ahem”, a few years, I’ve absolutely no idea where it is now, they’re pretty easy to misplace as it’s not like they’re big heavy things
Walk around your garage in flip flops. I use my toes exclusively to find inanimate , solid , large objects without fail.Just made me think of my gtt gearbox which has been dry stored for, “ahem”, a few years, I’ve absolutely no idea where it is now, they’re pretty easy to misplace as it’s not like they’re big heavy things![]()
An offset caliper is more accurate. The other side was fine, but this one was about 45 thou to one side, so the pad didn't slide in . Skimmed the mounting face of the carrier to move it all back to centre.A Squint caliper?
Fascinating.I don't know if this should be in a thread of it's own, not a lot of point as it is only one post, so I'll leave it here. If the Mods think different they can move it.
AVP Bellhousing conversion kit.
Early R8 (most production) used a carbon thrust Release bearing, which on the tiny 160mm clutch and about 4000rpm is fine. Late cars and all 1300cc R10 used a Guided ball type release which was also used with a stronger 180mm clutch.
If you are uprating an 8, 10 or early small engined Alp finding a Late Bellhousing is one of your tasks. These are getting harder to find and years ago Colombo the R8G specialist in France (now retired) did a conversion kit to adapt the early Bellhousing to the later type. These are now available through AVP in France.
I have only ever seen one of these on a Gearbox I overhauled years ago, it did not have the Clutch release lever and spring, so I noted it and left it at that.
The Latest 4 speed big box I have just completed had a damaged Bellhousing, which I think I have successfully repaired, but the customer had acquired an early bellhousing and an AVP kit to Fit if Necessary.
It became obvious to the customer that the rearward travel of the mechanism would be severely compromised by the kit and was looking into options for modifying it.
Once the box was built I had a look and a think and have come up with a solution that works.
The Issue
Better shown in the next pic
The mounting flange sits off the bellhousing face on a small raised pedestal which contacts the release fork holding it at Half Cocked position, now you could take a grinder to the fork, but it would be so weakened it would not have a long service life.
Solution:
I made up a reinforcing piece of Ally plate and had it welded to the bellhousing rear face, this is where the oil seal sits on Later types I left a register to centre it up through the hole for the input shaft.
Making a rudimentary Plug Gauge centres it all up on the Mill and the relevant diameters bored with the boring head I went in about 8mm deeper than standard, this then allowed me to take 7mm off the pedestal face.
That means you drill through as originally intended to fix the combined tube and seal carrier. The tube height to the bellhousing face is now the same as the original late type.
I trial fitted it to the box and it gives the same operating dimensions as the original.
The kit is clever as it requires no special tools, but there is a real chance it will not work properly, so what's the use.
If you are using the Gordini Turbo flywheel it is 5mm shallower than the non turbo versions, so in that case it may work ...
Having done it, I think it would be easier to fit a thicker smaller diameter reinforcing piece, so you could put the oilseal in the back ,as the original late type. Then you could pressfit a piece of tube into the now thick alloy plate to carry the bearing. This is in essence what Renault Did with the MK1 to Mk2 castings.
There will be more of these in the future, so it has been a good learning experience...
More Soon.
