Steve Swan
Irritating things:
This list seems to grow daily, must be my age. About 10 years ago we bought a huge LaZyboy Sofa (for the Boss to recline on) It's one that weighs about 3 tons and has to be dismantled to fit in your door.
The feet on it are pathetic, guaranteed to wreck your carpet very quickly.
Thus
This means you have to stick on extra feet to prevent said damage.
Coz of the small area to stick on they don't last long. I had the brainwave to use 3m trimtape which lasted months instead of weeks but eventually one came off and glued itself to the carpet and required surgery to remove!!
I decided to try to bolt the whole lot together and discovered the washer on the plastic slider is hardened and not bonded to the plastic as well as it might be, also the bolt is M7X1 !! a real Dick move by whoever made it.
With the Red mist descending I headed out to the workshop to find a solution. Found a bit of 50mm nylon 66 and set too........
Had to make 11 of them, that's right 11, biggest pain is notching the bottom to clear the other frame bolt which is why it had such stupid small feet in the first place............
Why is nothing simple, or is it just me...........................
New Project inbound and not a settee in sight.....
Thus
