I have a 125 main jet but its pinking at around 18-20 psi and I want to change it for a 135 main, is this something easy that I can do myself? Do you just remove the carb lobster top and undo the main jet in there with a screw driver and refit the new one in its place and do everything back up again? The Air Corrector is .90 so thats fine and the 2nd stage is fine too.. so its just the main jet I would like to do myself without having to take it to a tuner. Just wanted to check this was straight forward
Thanks.
oh... also... I was going to contact this company for the bigger jet as they are only a few quid.. and K-Tec want over £10. are these the same as the jets I need for my Solex carb as the webber? or if not is there anywhere else that supply them as cheaply? Thanks.
Weber Carburettor Specialist, Weber Authorised Dealer, Fastroadcars, Weber Carbs, Fuel Accessories, Fastroadcars - Main Jet for DGAV/DGAS/ICH
Thanks.
