5 GT Turbo Fuel tank leak - can i use one from 5 door renault 5
itzik
Hi,
I have the well known fuel leak, I couldn't get it to seal, it keeps leaking after a while, can I use a fuel tank from a 5 door renault 5? Is the GTT fuel tank unique?
TIA
Gtt tank has a baffle in, so need to check the 5 door one has one fitted.
Ok got it, my guess is that the baffle is a part of that leaky yelloy bung, so I guess putting a leak proof tank from a 5 door R5 might cause fuel starvation on hard corners or low fuel in the tank... what do you think?
